Use the following procedure to create accounts for different access levels in enhanced secure mode. You must be the administrator to configure the different access levels.
You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
Create an account at the auditor level for jsmith:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password create-user auditor jsmith Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password create-user command.
 Variable  |
 Value  |
 {auditor|operator|privilege|security}  |
 Specifies the access level for the user.  |
 WORD<1–255>  |
 Specifies the user name.  |
